External antenna connection
Kodran
I’m looking for a 4G broadband solution using a router that can take an external antenna. I am currently using a Huawei B535-232 on a narrowboat which is already fitted with an antenna
1 REPLY 1
MymsMan
You could consider the Three 5G external hub which connects to an internal eero router,  uses 4G signal if 5G weak
