Going onna cruise tomorrow
Chief73
Hi I'm off onna crusie around the Caribbean tomorrow I have purchased the ships WiFi and I have put a zero spend cap on my three account , the WiFi allows me to stream use social media watsapp calls vids etc just won't be allowed calls or sms but that's fine , my question is whilst on maritime at sea will I need to put my phone on airplane mode ? Will I need to turn off mobile data ? Data roaming ? Or both or none please, then when on land I can just use the local WiFi wherever I am
Hello.
Yes, it is generally best practice to put your phone into airplane mode while you're travelling on a boat. Wifi and other wireless features of the phone will work normally once you enable them.
1 REPLY 1
Hello.
