Greenpacket Y5-210MU Ethernet Cable Replacement
bhr
Recently received the Greenpacket Outdoor Hub. The modem works well, however I received a 5 meter Ethernet cable and not the 10m version I’ve read about online.
I was about to replace the cable with a 10m one off of Amazon but found that it might not as straightforward because the current one is exactly cut out to fit around the weatherproofed latch.
Where can I find one that fits the Greenpacket perfectly?
0 REPLIES 0
