on 24-05-2022 09:57 AM
Samsung Galaxy A70, 2 years and 6 months old, my battery has started to deplete much faster than usual. I am presuming this is a battery issue caused by recharging daily, does anyone know if the battery can be changed, how much this is likely to be and if this could be done in a 3 store or elsewhere?
on 24-05-2022 10:59 AM
Has this started recently or have you noticed a gradual decline? I ask just in case a recent update is causing the problem. I recently removed Microsoft Start and Norton as their latest updates quaffed rather than sipped my battery.
If you have the battery changed do a bit of research as not all batteries are created equal and may not last as long as you would hope. Do not believe the milli-ampere hour rating as the manufacturer can print any number they like on the battery.
