Ion
Ion
what pin do i need to set to listen to voice messages
Paddiewack
Superstar
Whatever you choose it to be. If you’ve set up your voicemail then that’s the one to use if you’re trying to remotely access your messages. If you’re in the process of setting up your mailbox then you can choose your own and there’s no default pin needed to do that.
1 REPLY 1
Paddiewack
Superstar
