Signal
Rich1
I’ve been with 3 network for more that 20 years not moved still the same postcode tf10….it was the best network now it’s the worst ever signal is  zero most days and when you put postcode into network coverage it says great coverage .. k just lies when you phone up to ask why they say just a small problem will be sorterd soon
lies lies lies
dont buy don’t get it unless you want to like your life on WiFi.  …. Just awful myself my wife my children my sister all her family all have the same problems when you complain they say well you can leave …. Thanks 3 network for nothing
awful
1 REPLY 1
Paddiewack
Maestro
Here we go again. No company would “lie” in the manner you describe. It’d be akin to corporate suicide. There has to be a reason as to why your signal is as poor as you allude. You mention the word “coverage” when talking about the network status checker but not status . There’s obviously an issue in your local area which however frustrating and annoying will be sorted. If you call 333 again and ask for tech support they should be able to give you a very rough idea when your issue is likely to be resolved.
