on 20-11-2025 10:01 AM
After a short while the digital display on my external hub goes off
Is this normal ?
on 20-11-2025 10:18 AM
Yes, But you can access the signal strength data by logging on to the hub
on 20-11-2025 01:08 PM
Thanks very much for that
Do you know how I make certain devices use the 5ghz channel and not the 2.4 channel as I have one device in particular that I would like to be using 5ghz
on 20-11-2025 04:42 PM
Devices (normally) connect to the internal eero wifi router rather than directly to the hub so device settings would be via the eero app or, depending on the device, in the device settings
on 20-11-2025 10:36 AM
Whats the best way to log on to the hub please
on 20-11-2025 12:20 PM
https://192.168.0.1 (ignore any certificate security warnings)
userid admin password on hub label
