11-12-2025 02:27 PM - edited 11-12-2025 02:37 PM
I have a 5G broadband Router in Worle, near Weston-super-Mare. Normally it works well.
Since this morning though the connection has been cutting in and out.
Network status says there is no problem.
Note, it only goes off briefly - a few seconds to a minute or so, but this is happening very frequently, perhaps a dozen times an hour - or more.
Any suggestions?
on 12-12-2025 09:33 AM
OK, I have solved the problem. It was nothing to do with the 5G Hub.
The WiFi on my PC is obviously dying. Using an old USB WiFi dongle solved the problem.
Thank you for your help.
While I'm here does anyone have an explanation for why my connection is so much faster via a VPN than without it?
on 11-12-2025 05:36 PM
What hub model?
The following applies to the Y5-210MU external hub:
Reset (not just reboot) hub, if that doesn't help, Try:
on 11-12-2025 07:21 PM
Hub Model is MC888
