Three 5g outdoor hub by Greenpacket - Speed Drops
Blinky3i
When I reboot the hub and Eero router I get speeds of 400+mb/s, however after a day or so speeds settle at around 100mb/s, I reboot the hub and router and speeds go up to 400+mb/s - why does this happen?
1 REPLY 1
Hello there, Blinky.
It's not entirely clear what would be causing that. It could be Wifi related, are you able to connect a device to the Eero to test its speed over ethernet? If so, you could wait until the next time it slows down, and run a test with a device plugged in as well.
