on 04-20-2023 07:28 PM
on 04-21-2023 02:57 PM
Hey @quig,
I don't recognise the Ulefone, and I couldn't track it down on any of our internal support systems, so it doesn't seem like it's a manufacturer we work with. This doesn't absolutely mean the feature won't work, but it does limit how much support we can provide. If you haven't already, I'd check with Ulefone if they have a support line or email address.
If you check in the Network Settings, there's no option for VOLTE or 4G calling there at all? It may also be worth resetting your network settings, or trying a factory reset as I've seen a couple of situations where doing this caused missing options to reappear.
I don't have a specific timescale for particular regions but the switch off will be carried out throughout this year and next. Customer services on 333 should have a record of the text sent to you, and may be able to discuss further options if you can't get VOLTE working on your current phone.
on 04-21-2023 08:04 PM
Does 3 limit features depending on version of Android or iOS?
on 04-21-2023 04:17 PM
As I said, Enhanced 4G LTE Mode Use LTE services to improve voice and other communications (recommended) in Settings>Mobile networks is enabled. Resetting network settings made no difference. I haven't tried a factory reset yet.
on 04-20-2023 08:40 PM
Did the VoLTE previously work on 3 or were you on another network?
on 04-20-2023 09:21 PM
I think it was three, but as it doesn't say 3 in the screenshot, I can't be certain.
on 04-20-2023 10:52 PM
You may need to wait for a moderator to pick this up but I would not surprised if 3 does not support your phone. Your on Android 7 and, I think, we are now at 13 so this may be a reason VoLTE is not available. Also may not work if you don't have the latest 3 software.
