on 14-01-2026 09:18 PM
Morning all,I think ive got a 2.4g cam and can't get it connected to my three dongle. Will the dongle be 5g?
If so...how i change it?
on 15-01-2026 07:16 PM
You usually need to pair the camera with your wifi network. This is normally done via an app that "scans" for the camera and allows you to configure it with your wifi network details ie network name (SSID) and wifi password. Once pairing is complete, it should then connect automatically.
There are some FAQ's and manuals on the products website - https://support.ezviz.com/product/c6n/9046 Have you followed the pairing instructions?
on 15-01-2026 03:37 PM
Soyealink Mobile wifi...Model E5783-330...From the Three Store
WiFi camera won't connect...EZVIZ CS-C6N
on 15-01-2026 09:42 AM
Hi there @Miko,
What's the full model name for the dongle/device that you have?
Michael
