on 23-11-2025 09:22 PM
I've had my phone s24 fe, for close to a year. However the last month or so I get no signal what so ever when home. I can not call anyone or recieve phonecalls. This is very frustrating and I need my phone for work.
I have tried all the tips and tricks and the network coverage just says, we are working on it and has done for months.
on 03-12-2025 11:35 AM
Hi again @Sazzery22,
I wanted to check again with you on this - do you experience similar signal problems when away from home, or is just when you're there?
I'd recommend chatting with Customer Services if this continues to impact you, as they'll be able to look at options for your service.
Michael
on 24-11-2025 09:47 AM
Hi there.
Welcome to Three Community.
Is it just at home you're having the issue?
