on 15-07-2025 08:19 PM
Hi, my son has gone to Spain and yet again his data roaming is not automatically working. He’s had the text to say his go roam pass is active, he’s tried to manually select a network but none work. He’s switched phone on and off, he’s checked his spend limit, what else can he do?
on 25-07-2025 01:23 PM
Hi @MM2,
We didn't hear back from you, please let us know if you still need help with this, or if the issue was solved.
on 16-07-2025 11:58 AM
Hi @MM2,
Sorry to hear that your son is having trouble with roaming, is it specifically data that isn't working? Can he make and receive calls and texts?
