on 12-08-2025 12:31 PM
Hi, if I purchase a go roaming data today, 12 August, how does it work as we don't go until the 19th Agust? Do you have to wait until the day of leaving to purchase it? Thank you.
on 13-08-2025 12:53 PM
Hi @DevonMaid,
I'm assuming you're looking to buy a bundle of Go Roam passes for visiting Europe? Yes you can pre-purchase these. The passes won't activate until you access your allowances in an applicable destination i.e you make a call, send a text, or use mobile data.
Hi @DevonMaid,
