Connection problems
Miila
Is there any problem with the network? My unlimited services are suspended because of a spend cap that I didn't set up. Can't call Customer services and the message on my account says I need to...
2 REPLIES 2
Hello there, Miila.
It doesn't sound like a network issue. It sounds like something on your account needs sorted in order to restore normal functionality. If you head through to the Support Team on chat, they will be able to check it out and sort it for you.
Geluk
Maestro
Just dial 333; simples😂
