on 14-02-2024 01:47 PM
My 3 4G/5G hub can connect to the internet, the wifi works and I can browse the net. However, on nearly every other non-browser application, whether that be Discord, Microsoft Teams, Steam, anything not ran through a browser fails to fully connect. Discord allows text but not voice chat, Microsoft Teams fails to load, Steam can't connect to servers, my VPN cannot connect. I've tried going to the extent of turning off the firewall entirely with no luck. Other similar broadband connections work on the same device, it's localised entirely to this one router.
on 14-02-2024 05:45 PM
Try changing the APN to manual 3internet and IPv4 only.
on 10-11-2024 10:36 PM
Thank you! Now I can use BBC Sounds on my phone without having to disconnect the wifi to start the app.
On a ZTE modem, the setting is in My Router/Data - APN, then create a manual one that matches the auto settings, but set the PDP type to IPv4
on 17-02-2024 12:16 PM
Ah, not to worry, sussed it out and apps are working, thanks
on 09-09-2024 05:25 PM
How on earth do I do this? What is an APN?
I can connect ALL other devices i.e. PS4, laptop and TV box but, not my Epson Stylus printer I have had 2 routers from 3 but neither will connect? is this a bandwidth issue???
on 19-06-2024 11:13 PM
How do I change the apn?
Right now the three SIM card which came with the 5g hub is inside the hub.
Do I get this out and put it in my phone and go into the settings then mobile network and change the apn to manual.
on 20-06-2024 12:29 PM
Hey @Megaman,
Welcome to the Community!
Changing the APN on a mobile device wouldn't alter the router settings.FYI : IPv6 Prevented VPN Connection This article contains some information that may help you. Some other users have found this helpful with issues relating to VPNs.
Let me know how you get on.
Kate
on 28-05-2024 11:38 PM
Man I want to kiss you so bad thank you sooooooooooooo much I have been strugle for weeks in this thank you so much ❤️
on 14-02-2024 07:02 PM
Thanks, took me a bit to find how, but that seems to have worked!
on 17-02-2024 11:49 AM
Where in the settings is it please?
