on 27-07-2023 09:35 PM
Just got a 5G Hub today as I'm currently living in a HMO which has horrible Wi-Fi and I thought this might be a solution but the bl**dy thing won't even detect the sim card. Yes, I've put it in both ways but nothing works.
I'm extremely angry cause I phone up support to get told the lines are closed which is just disgusting as every company should have 24/7 support for this kind of thing.
I need some kind of a fix asap as I can't do anything right now and I will be cancelling if this isn't fixed asap.
on 19-08-2024 01:43 PM
I had to put my Sim card into an old iPhone and use that as the WiFi
on 01-08-2023 03:27 PM
Might not be your issue at all but I tried to set mine up the very day the kit was sent me in the post. Silly me spent an hour or more trying everything I could to get it working and when I eventually gave up and called support they said my SIM wasn't activated just yet. It would have activated later that day but they did me a favour and gave it a nudge to activate it within the hour.
Hope you do get it working.
on 28-07-2023 03:42 PM
Which 5G router do you have?
Have you tried the router SIM in a phone?
The SIM should only go in one way. There should be little resistance when inserted fully in.
When SIM is inserted into the router. Access the web-configurator (192.168.1.1 for Zyxel router) and look at Cellular Info > SIM Status. The SIM Card Status and IMSI should be displayed. The status will be either, Available or None.
