5G hub (Greenpacket Y5-210MU) dropping wired connection after a few days every few minutes
JohnR
First, it seems I'm not alone: https://www.ispreview.co.uk/talk/threads/drop-out-problems-with-new-three-outdoor-hub-y5-210mu.42890...
tl;dr - I've only had the Three 5G broadband package for 1 week. I didn't alter the 5G outdoor hub  configuration, which is running firmware 130.00100.113.024. After 6 days of flawless operations with minimum 300/20 Mbps downlink/uplink, the 5G outdoor hub started closing the ethernet connection intermittently every few minutes, and the only fix (so far) is a reboot of the hub. I'm willing to help the Three engineers debug this (I have networking experience), but if it can't be properly fixed (firmware update?) or if they aren't interested, then I'll have to cancel the contract as this is a deal breaker.
Details:
The outdoor hub (Greenpacket Y5-210MU) seems to intermittently close the ethernet connection. I've debugged this several ways: with a laptop directly connected to the hub via the PoE, via the eero, via its own web GUI (192.168.0.1).
  1. the web gui's advanced > system > ping (which pings directly from the hub, independently of any connected router/eero/device); this always works fine, so I know the 5G connection is working
  2. a laptop connected directly to the hub; when it happens the laptop OS reports ethernet disconnected
  3. the supplied eero 6 router; when it happens, the eero's led turns red, and the eero app says "Internet Offline, Wired Connection Not connected".
  4. The syslog logs don't show anything suspect, which to me suggests a memory leak of a process running on the hub (syslog logs downloaded from web GUI > advanced > system > maintenance > syslog > download)
128 REPLIES 128
sargentdel1
Same issue for me. I’ve had to lock mine to 4G only and that seems to have stabilised it for me, but defeats the purpose of having a 5G router.
AndyFSSmith
Found it in the settings, thanks. I’ll see how I get on
sargentdel1
Sorry. I’ve only just seen your message. Hope it works out for you.
AndyFSSmith
Can you explain the steps to do this please. Think this may solve my issue as the 5G is not that great where I am and looking at the hub it’s only connecting to 4G most of the time anyway. Thanks in advance.
AndyFSSmith
I’m not the most technical but wondering if it’s the lease expiry that’s adding to the issue?
JohnR
It's the ethernet link that is going down, the same as if the Ethernet data cable was physically unplugged for 30 seconds then plugged back in (it's still getting power as it's using PoE, it's just cutting off data).
If there was a DHCP lease expiry from the Three DHCP server then that would not be an intermitted issue like the one I described, and it wouldn't have any bearing on the ethernet link state
AndyFSSmith
Fair enough - makes sense. Let’s hope @JonathanB can help with a solution.
Hi @JohnR,
Thanks for the feedback. I've flagged this with some relevant colleagues and will let you know if we're able to determine what's happening here.
bod
Issue still happening and no response from three...
sargentdel1
Any update Jonathan?
