on 25-04-2025 12:42 AM
First, it seems I'm not alone: https://www.ispreview.co.uk/talk/threads/drop-out-problems-with-new-three-outdoor-hub-y5-210mu.42890...
tl;dr - I've only had the Three 5G broadband package for 1 week. I didn't alter the 5G outdoor hub configuration, which is running firmware 130.00100.113.024. After 6 days of flawless operations with minimum 300/20 Mbps downlink/uplink, the 5G outdoor hub started closing the ethernet connection intermittently every few minutes, and the only fix (so far) is a reboot of the hub. I'm willing to help the Three engineers debug this (I have networking experience), but if it can't be properly fixed (firmware update?) or if they aren't interested, then I'll have to cancel the contract as this is a deal breaker.
Details:
The outdoor hub (Greenpacket Y5-210MU) seems to intermittently close the ethernet connection. I've debugged this several ways: with a laptop directly connected to the hub via the PoE, via the eero, via its own web GUI (192.168.0.1).
on 12-12-2025 07:05 AM
My Y5 goes offline and internet is not restored until I reboot. This happens once every 5 to 8 weeks early morning, used to be daily before I turned IVP6 off.
Can you point me to the correct thread?
on 12-12-2025 11:51 AM
I'd like to second this. Exactly the same issue. Had been fine for 40+ days, now every morning I wake up to no internet and a red light until I restart the router. Has been like this for the past three mornings. Every time it takes the router over an hour to reconnect and seems to take longer each time I do it!
on 19-11-2025 07:36 PM
For the past 3 weeks, after 2+ months of no issues, all of a sudden I started to have constant pauses in connectivity, with the hub dropping the LAN connection again -- 10-20 seconds of no connection, then back up again, reoccurring every half an hour, sometimes more rarely, sometimes more often. 2 weeks of high frustration.
I changed the hub mode from the default "IP passthrough" to "Routing" (and set a DMZ address for my router). Disabled Firewall, enabled all ALGs.
This resulted instantly in a stable connection.
It seems something is wrong with the IP passthrough upstream on 3's network which deals with IP assignment and routing (my Greenpacket hub has received no update or change).
Maybe this will help others as well.
p.s. For what it's worth, my router is an Asus RT-AX59U, now configured with a static IP 192.168.0.2 for the WAN, on the local network of the Greenpacket hub which is 192.168.0.1.
on 31-08-2025 12:36 PM
After months of lurking and frustration, just wanted to chip in and report I'm in the same boat.
I'm on software version 130.00100.113.024 and tbh, I've had this connection loss issue on and off for almost a year. I got this hub shortly after it launched. When it works, it really works, fabulous stuff. But much like everyone else, I'll wake up and find the internet dead / eero red light etc and need to reboot the hub.
Trouble I'm finding these days is that, when rebooting, the hub takes well over an hour to reestablish the 5G connection. The LED just reads 'ON' for ages and ages and then one moment will suddently spring to life and start giving me numbers.
I've done all the usual stuff. Full reset, power cycles, SIM out, SIM in, disabled Scheduled Reboot and TR069. Won't lie, I can't face Three Technical support as they'll just tell me to do everything we've already been through.
What is up with this dang thing??
on 31-08-2025 12:57 PM
I addition to the frequent disconnection problem there is another problem with no/slow reconnections and it appears from PM and posts here that Three are investigating involving the Eero software? Has @JonathanB been in touch with you to collect details of your Eero?
I created a little utility to help monitor the state of the outdoor hub https://community.three.co.uk/t5/Broadband/InquireHub-3-Three-Greenpacket-Outdoor-router-Y5-210MU-In...
It might help you determine whether the hub thinks it has an internet connection when the the eero is not showing connected and to download the hubs system logs for further analysis
on 26-11-2025 12:08 AM
Hello! It was an age ago that you gave this reply, but just wanted to give a little update.
You are definitely onto something with the TR069 business. When I eventually got it disabled, I had a near record 45 days of connectivity. It did eventually succumb to the Red Light of Doom, but rebooting the hub did its business and it went for yet another 30 days.
I will say that sadly the really slow reconnection is still an issue. If I reboot the hub, it takes just over an hour for it to start showing strength numbers - it'll just display 'ON' for the entire time leading up to that.
Also annoyingly, I got the Red Light of Doom last night, rebooted, all fine, but a mere 24 hours later I'm having to reboot again. All the settings I tweaked as per your instruction have stayed the same. Here's hoping I'm not in a 'disconnecting every 24 hours' cycle now!
on 26-11-2025 11:27 AM
The 24 hour rebooting usually occurs around 4am and can be disabled by changing the Scheduled reboot settings on the Advanced->System->Maintenance page
I am currently up to 45 days without reboot.
Note: Only change one setting at time, when I changed Interval and set Disabled at the same time the display showed Disabled as set but it still rebooted every 7 days!
Touch wood, I have never experienced the slow reconnection issue so haven't had the chance to look at the hub logs to compare with a normal reconnection.
I enable TR069 during the night and disable it during the day, and so still see occasional reconnections but only when I am asleep and only, on average, once a week
on 20-08-2025 01:06 AM
This is an interesting thread, one that I think I can relate to.
A used to have the THREE indoor hub, and it worked pretty good, but I moved to the outdoor hub on a new contract because the mast is across the street from me.
I switched to the outdoor hub and im finding that websites are slow to load, streaming buffers, and it's just not an enjoyable experience.
I'm getting 92% signal on 5g and my speeds tend to be around 200mbit/s. The issue for me is random packet loss. I've had pings running to internal devices, both wired and wireless with no packet loss. However, any internet bound data such as pings to Google.com and 8.8.8.8 are loosing about 5% of packets within an hour window on average.
I've replaced the ethernet cables, moved the device to a different location, reset the device, tried wired and wireless devices and its all the same issue.
I had the device and PoE injector replaced today, and for 30 mins, it was fine, but then back to the same issue of packet loss.
I may need to go back to the indoor hub, because this outdoor thing seems unreliable.
I dont use the Aero thingy. I switch the hub to routing mode as my house uses ubiquity for WiFi.
on 23-08-2025 02:02 PM
Another update... still going strong, no drops, no network outage alerts from various IoT devices, all is looking good and positive.
on 21-08-2025 10:52 AM
So just an update on this... I've disabled the auto reboot feature, and also the TR069 features, and I've had a clear run for about a day now... Prior to this, it was a problem constantly... Will continue to monitor, but things are looking promising!
