5G hub (Greenpacket Y5-210MU) dropping wired connection after a few days every few minutes
JohnR
First, it seems I'm not alone: https://www.ispreview.co.uk/talk/threads/drop-out-problems-with-new-three-outdoor-hub-y5-210mu.42890...
tl;dr - I've only had the Three 5G broadband package for 1 week. I didn't alter the 5G outdoor hub  configuration, which is running firmware 130.00100.113.024. After 6 days of flawless operations with minimum 300/20 Mbps downlink/uplink, the 5G outdoor hub started closing the ethernet connection intermittently every few minutes, and the only fix (so far) is a reboot of the hub. I'm willing to help the Three engineers debug this (I have networking experience), but if it can't be properly fixed (firmware update?) or if they aren't interested, then I'll have to cancel the contract as this is a deal breaker.
Details:
The outdoor hub (Greenpacket Y5-210MU) seems to intermittently close the ethernet connection. I've debugged this several ways: with a laptop directly connected to the hub via the PoE, via the eero, via its own web GUI (192.168.0.1).
  1. the web gui's advanced > system > ping (which pings directly from the hub, independently of any connected router/eero/device); this always works fine, so I know the 5G connection is working
  2. a laptop connected directly to the hub; when it happens the laptop OS reports ethernet disconnected
  3. the supplied eero 6 router; when it happens, the eero's led turns red, and the eero app says "Internet Offline, Wired Connection Not connected".
  4. The syslog logs don't show anything suspect, which to me suggests a memory leak of a process running on the hub (syslog logs downloaded from web GUI > advanced > system > maintenance > syslog > download)
125 REPLIES 125
cadmaster
I was seriously considering replacing my fibre broadband with the 5G Outdoor Hub but reading this and various posts on similar and other issues I don't think it is worth the risk unless Three are going to upgrade/replace the equipment or firmware - is there any prospect of this in the near future?
MymsMan
From reading the forums it might appear there is nothing but problems with this hub but, touch wood, I am a very happy user.
Initially I was worried whether I would get any signal in my location but with the hub mounted on an aerial pole I get a median download speed of 300Mbps with a maximum of 750Mbps on occasion.
Three give you a thirty day return period so I think it is worth trying it out for yourself.
sargentdel1
Even more impacted customers, yet three still can’t be bothered to reply…
philoez
Same issue here. Router disconnects every couple of hours and needs a reboot to reconnect. Any update on this? @JonathanB @JohnR ? If the situation doesn't improve I will switch to a different provider, as this is getting way too frustrating
Willbut90
Same here!! I can be on the WiFi then all of a sudden erro router will go red then that’s it! Have to always hard reset by unplugging both units as nothing else works! Then Woke up this morning 5am to it red went on app said no internet connection for 2 hours 25mins! And again had to hard reset! It’s happend another 5 times since then today and again each time had to hard reset (unplug both units) can’t have this every few hours or so everyday it’s ridiculous and there a definite problem with these units as it’s affecting a lot of customers it seems!! Bring back the old MIFI boxes they where amazing!!!!
philoez
Same issue here. Router randomly disconnecting during the day (every two hours or so) and needs rebooting everytime to  reconnect. Any updates on this? @JonathanB @JohnR  It is getting very frustrating and might have to return the device and switch to a different provider.
RichGee
Same issue here, Installed mine last Thursday and it's been flawless. Got home today at 5pm and it's gone down twice, needing the 5G hub rebooted to fix.
Really disappointed as I've been getting great upload and download speeds, looks like I'm going to have to cancel and stick with Virgin Media.
RichGee
I've decided to return mine, the last few days have been terrible and had to reboot the hub 2-3 times daily.
JohnR
I did some more looking around. The hub generates almost 6MB/hour of syslog data (thats just syslog). 25MB for only the last two log files covering a mere 4h or so. That's immense. Looking inside, it seems everything is at ultra verbose level, including even the original C language source name that was compiled, e.g.
Mon May 12 20:46:23 2025 user.err : 9746:[src/at_parse.c,at_parse_response,207]at_parse_response in +EDMFAPP:6,9,"NR PCC RX1",-115,6,-85,-255,-255,1,4,-119,str_len=46
The firmware seems like it needs a much better configuration because this is way too excessive and could be the cause of system hangs and other problems.
If the logs are trimmed and truncated to the last few hours then thet would not be very useful to debug problems happening over longer periods of time.
Someone should really look at this.
I also replaced the PoE injector with a high quality one with an integrated high efficiency switching power supply, because the one provided really doesn't look very reliable, a no-name device that feels really cheap. Voltage in PoE needs to be very clean as it's added on top of the data signal and can perturb it ... which may explain the link problem I described in the first post of this thread.
I also disabled the scheduled reboot every 7 days. Why is that enabled by default? If the device must be rebooted every 7 days for it to work and me to lose connection and have interruptions every 7 days, then it's not a reliable product and i don't want it. Three should NOT be selling it like this with this periodic reboot enabled by default. It reflects badly on you.
I also disabled ipv6 on the WAN 5G connection (in Mobile Network > APN > options).
I will continue to monitor the behavior.
Hi @JohnR,
I'm not sure if you got a chance to check it, but I sent you another PM. We'd like to take a look at the syslog files if you're able to share them. We've eliminated some possibilities from what we can trace externally, but we can't see everything that's going on internally with the router.
