5g Outdoor Hub wall Bracket
Dc52ltr5862
Hi, I've got my outdoor hub ordered for delivery. I'll almost certainly wall mount it but am not sure about the bracket itself. It looks like it will swivel vertically but will it do the same horizontally, ie side to side? This would make it a lot easier for me to point it more towards the local 5g mast. Thanks in advance, David.
Sal09
No it doesn’t. You can just move it  ⬆️ up and ⬇️ down. It doesn’t rotate.
3 REPLIES 3
HibernationGuru
According to the specs on the manufacturer’s website, the greenpacket outdoor hub has an omnidirectional antenna inside of it.
As long as you position it on the side of your house which has the strongest signal, changing the angle of the unit itself will make very little difference.
Sal09
Dc52ltr5862
Thank you... 👍🏻
