5g router issue connecting device via LAN
LoobyLin
New to this forum.  I Can’t connect Neohub smart heating via Ethernet connection.  Working until yesterday but tech support don’t know what’s wrong! Is this normal?
1 REPLY 1
jr0
Hi
Are you using the provided cable to connect to Three 5G Hub NR5103E router? Or other?
It could be that you need a crossover cable instead of a straight through cable. Or the other way around depending on what cable you using.
Read the differences between them and how to identify them here
