Heatmiser Hub Connection Issues
Garyhun
has anyone successfully connected their Three 5G router (Zyxel) to the above heating hub?
Garyhun
Funnily enough I am going to reply to my own post because after some sleuthing on this site I found a solution that works.
So if you have the same issue, the solution is to log on to your router as admin and then go Network Setting>Broadband and then click on Modify in ETHWAN.  In there just change to IPv4 Only in the general setting and that's it.
2 REPLIES 2
Garyhun
Hi @Garyhun,
Glad to see you found a solution, and thanks for taking the time to confirm what fixed it. Hopefully if anyone else has an issue with that heating hub, or similar devices it goes onto help them too.
