2 weeks ago
I’m coming to the end of my 5G broadband contract with 3. It’s been generally excellent: I get a reliable 100-150 mbps. I will stick with 3 but should I get the outdoor hub instead? Will I get faster speeds?
2 weeks ago
Hello there, Jon.
I'd generally only recommend sticking with what you have if it works already. There's no way to guarantee there would be any difference to your connection if you changed to an outdoor hub.
