on 11-11-2023 10:41 PM
About 2 weeks ago my PS5 stopped connecting to my internet even though every other device connects and works to the internet. I’ve read multiple other posts about this and get the impression I need to log in to the three admin page to change the setting but when I put this (192.168.8.1) into the browser nothing loads leaving me with no options to get this fixed please can someone help me
on 13-11-2023 11:13 AM
Hi @RyanBeves If your 3 router is the same as mine then it's 192.168.1.1 that gets you into the router configuration pages.
on 14-11-2023 07:11 PM
When I type this into my browser the page doesn’t load.. I’ve tried google and safari m.. does it have to be on a laptop or computer?
on 15-11-2023 02:06 PM
Hi @RyanBeves
Technically any device connected to your router and that has a browser should work. The admin pages aren't always optimised for mobile though, so you may find it a bit awkward to navigate.
If you've got the Zyxel router then you can also try the Three Broadband App, or there is a ZTE app for routers too. These might work better if you're dependent on using a mobile or tablet.
