on 24-05-2025 12:11 AM
Not a request for help but posting in case that it helps others needing remote access to their home network.
There have been several reports of three blocking inbound connection using the port forwarding technique
I have succesfully connected to devices on my local network without needing to open ports or know the current external WAN address by using a VPN connection.
I already had a cheap nordVPN account (good cashback from a cashback site) so it made sense to use that rather than another VPN supplier but principles should be same.
My eero router does not support VPN installation so that was not an option
I already have an always on windows computer on my home LAN so it made sense to use that but I could have used a Linux or MacOS device, theroretically it might be possible to use a Humax but it might not be powerful enough and difficult to install the VPN client.
on 16-09-2025 04:12 PM
Unfortunately Nord have decided to drop support for their meshnet product claiming lack of interest (they failed to advertise it)
So I have now set up TailScale instead and while some aspects like setting up a subnet router were a bit fiddly (it was automatic in Meshnet) others were simpler.
Overall TailScale works well and I can remotely connect to all my home devices without needing to open any ports on the router.
ZeroTier is another product with similar features but I haven't succeeded in setting up the subnet routing with it yet - I may not bother
on 03-06-2025 07:36 AM
May I suggest tailscale? Which basically the same but free. You need some kind of server inside though. A RPi should be fine
on 03-06-2025 09:01 AM
I agree tailscale would have been a good alternative but since I already had a Nord contract (less than £1 per month after cashback) it made sense to use that
