on 11-04-2024 10:56 AM
Does anyone have their home router set up with Data Roaming on? And if so does it make any difference to your download speed and reliability?
I assume having a UK router with Data Roaming switched on will not cost anything but not sure if it would improve the signal in an area where the signal is weak for all networks.
P.S. I am running tests but the mobile signal has been poor for 3 months with ongoing "issues" according to Three with no timeline when they will be resolved. Therefore I don't have reliable data to check at present.
11-04-2024 11:18 AM - edited 11-04-2024 11:20 AM
I have a HUAWEI router with data roaming activated and having just toggled it off and back on,I can say it makes no difference. Call 333 option 4 option 3. That’s tech support. They can give you more information on when your issue is likely to be resolved.
on 11-04-2024 01:43 PM
"They can give you more information on when your issue is likely to be resolved."
If this forum has proven anything, is that Three customer services appear have zero ability to know what Three are doing.
In fact, it would seem at times that they don't even seem to work for Three.
For example, the number of people forced by mind bending frustration to seek THIS forum out to just get a return for their router instigated!!!
If I had a penny....
on 11-04-2024 01:47 PM
Well I think that’s a backhanded compliment to the the forum.
Could be wrong though!🤔
on 12-04-2024 01:08 PM
Yep this setting only affects usage abroad. UK providers only allow domestic roaming for emergency service calls, and this kicks in automatically when your own provider has no signal.
I'd generally recommend leaving Data Roaming off, unless you're abroad and want to connect. It's pretty rare, but you can get French signal in parts of Dover on clear days, and in other coastal regions you might pick up a connection from a cruise ship. I don't think this is particularly likely on a router as opposed to a MiFi or phone, but you never know.
