on 09-03-2024 03:05 PM
I have used MC888 hub for threedays. but the wired connection dropped more than two times a day. And the connection couldn't come back without manual actions, cable unplugged and plugged in or restarting the wired device which is a WiFi Mesh. When the connection drooped, I logged in to the hub management page and there is no wired device lised on the connection table. I tried to set a fixed IP for my Mesh, but there wasn't no improvement. I tried to contact Three's support, but I can't get any help. Does anyone have some tips on this issue?
Thank you
Max
on 26-03-2024 10:56 AM
The symptoms you describe are similar to what I experienced with this router. Here's how I fixed it:
