Premium numbers
BJ
How do I remove blocked premium numbers
Paddiewack
Superstar
Either by going into the Three app and raising your spend limit as these numbers aren’t included in your allowance. I’m also not sure if Three apply a premium rate restriction by default (although I don’t believe so) in which case you’d need to speak to customer service. Your starting point though is the Three app.
Best of luck.
4 REPLIES 4
Paddiewack
Superstar
Best of luck.
Just to confirm, you're spot on here @Paddiewack, premium numbers should be enabled by default, and it would be the spend limit, or underlying credit limit for the account preventing this most likely.
BJ
Thank you for your reply
Paddiewack
Superstar
You’re very welcome!
