on 12-02-2023 05:40 PM
My phone is only shows two bars for the signal and I'm sat in front of my plug in signal box (router). My TV also keep buffing, with waiting for a signal. I have pressed the reset button but still the same.
on 12-02-2023 05:55 PM
Hi, try https://www.three.co.uk/support/network_and_coverage/network_support?id=3sms_out_up_sms_2 which takes you to our dear friend the network status checker. If all is okay post the first half you postcode or town then you may get a response from someone in your area. If it continues try 333 tomorrow.
