on 24-05-2025 09:36 AM
Its been 3 days i am unable to make and receive calls? The issue has still not been solved?
on 24-05-2025 10:39 AM
It is the post code. 3 has still not solved the issue after 3 days.
on 24-05-2025 10:43 AM
How about WiFi calling?
on 24-05-2025 10:51 AM
Wifi calling works fine. Just cant make and receive calls for past 3 days.
24-05-2025 10:37 AM - edited 24-05-2025 10:38 AM
Are you absolutely sure it’s a network issue and not your handset? Have you put your postcode into the Three status checker?
