WiFi calls
Dawniebarks
Still can’t make WiFi calls for 3 weeks now
4 REPLIES 4
MichaelP
Hey @Dawniebarks,
Thanks for raising this.
Does the Wi-Fi calling option still appear on your device? Which make and model are you using?
If your phone is a dual-sim device and the Three SIM in SIM slot 2, please try this in SIM slot 1 to see if this helps.
Also, please check if any software updates are available, and that VoLTE is enabled.
We'd also recommend complete a reset of your phone's network settings. If you're able to share the make and model you are using, we can confirm the steps required to do this.
Please note: this will remove Wi-Fi and Bluetooth history/passwords.
Michael
jr0
Key player
Does your WiFi calling kick in? And what handset do you have
Dawniebarks
iPhone 11 max pro
have tried everything to turning off phone resetting WiFi on phone  restarting home hub
Hi @Dawniebarks,
Have you checked to make sure your iOS and carrier settings are up to date?
Can you try putting your phone onto airplane/flight mode, then reconnect to your Wi-Fi whilst leaving the device on flight mode? This should help make sure that a weak mobile signal isn't preventing Wi-Fi calling from kicking in.
Let me know if testing a call like this works, or if it still fails?
