on 24-10-2023 12:40 AM
Hello,
I got a 5G Home Broadband one month ago, and I had an excellent reception for the first week - DN over 500 Mbps, UP over 70Mbps. But, the speed started dropping significantly (DN: ~ 100 Mbps, UP: ~5 Mbps) and frequently disconnected more than five times per day. So, I have to restart manually; otherwise, I should wait more than 10 minutes to reconnect. I contacted the Three tech team more than four times but couldn't solve the issue.
Now, I realise that the router is connecting to some masts around 4 miles away even though there is a mast within 0.2 miles near my home. I understand we can't select a specific mast, but I wonder why my router always connects to the far-away ones. These masts, including the one closest to me, have Band 1,3,20,28. So, I also manually selected the bands 1,3,20 and N78. But my router is still connecting to the far-away ones.
Does anyone know how to solve this problem?
Thanks in advance.
on 01-11-2023 06:03 PM
I found a kind of solution from this forum. I changed the setting as below, and now my router sees the cell tower near my home, and the speed returned to excellent. DN: >500 Mbps, UP: 5~90 Mbps.
3 weeks ago
Like to say thanks,
This has helped me with my connection & speed.
on 01-09-2024 07:19 PM
Sorry I have similar issues but can’t see where I could make these changes.
5g coverage in my area is terrible so already use ipv4 only.
on 02-09-2024 12:09 PM
Hi @Graeme85
We're sorry to hear the signal has been letting you down. Have you been able to check this on our Network Status checker to see if there any known issues or planned work in your area? How long has this issue been going on for?
Michael
on 02-09-2024 06:00 PM
Unfortunately been for some time. 5G isn’t great in the area we moved here mid July.
I have changed the settings to 4G only, at the start could get anywhere between 40-70mbps dl but upload no more than 3mbps.
unfortunately recently I’d be lucky to clear 20mbps dl and majority of the time less than 15 mbps.
I see people changing some setting to work better but unfortunately on the MC888 I can’t see cellular band.
Think I’ll need to argue my case and end contract without a fee and switch to actual broadband. Even streaming apps like Disney or Netflix struggle with buffering or basic loading now.
on 03-09-2024 12:50 PM
Hello @Graeme85
Thanks for getting back to us, and we understand that must be frustrating to experience after you moved there in July.
Have you previously reached out to customer services to discuss options for your account due to the drops in speed that you're experiencing?
Michael
on 03-09-2024 12:54 PM
Tried customer services it’s very repetitive with no better outcome.
on 22-06-2024 11:49 AM
Sorry jumping in as I am having constant variable speeds, using speed checker as a diagnosis I see what mast areas I am receiving and the ones that seem to provide better connection speeds.
how can I change the settings? Got access to ZTE site but nothing seen that may change the situation so far.
Any guides would be appreciated.
on 02-11-2023 01:43 PM
Hi @metoo6000,
Did you use three.co.uk for the APN? Cell bands can be hit and miss as it'll depend on the individual mast what is supported, but it's good to experiment with N78 and a mix of the B bands. I'm checking into the situation and will let you know on our PM conversation if we can find out what's happening with the nearby mast.
