5g Hub started great - now very slow speeds + unreliable connection
joespa89
I got a three 5G hub last month after making the switch from regular broadband. Speeds and reliability were great, anywhere between 150-300mbs dl, and no drops.
Until today when I noticed that my work VPN kept dropping (I WFH). Now I can barely get a stable connection, despite the app saying I have 5/5 strength signal, and nothing changed in terms of setup. I phoned support twice who assured me that them resetting it from their side would fix things, as well as cleaning the sim. I was skeptical given I work in IT, but I gave it a go. No joy, and if anything the performance has got worse. I don't want to phone again to be told to do a factory reset again. Has anyone had any similar issues, and any luck improving the situation?
I can't even complete a download speed test due to the connection dropping, and a ping test seems to show a fail every 25/30 or so packets. My download speed test on the PS5 has went from 150+mbs to 14.5 mbs.
I really would like to fix this as I can't get fibre and it was working so well initially, but I might be forced to cancel my contract sooner rather thn later if it doesn't improve quickly.  There just seems no explanation for it. Hub model is NR5103E and firmware version is 1.00(ACBJ.0)b12.
Thanks in advance for any suggestions or help. I really don't want to phone support again to be told to factory reset!
80 REPLIES 80
Derkins
(External unit. 5G tower 300m away)
On my phone - 720Mb...pretty good as tower isn't in line of sight.
Got the 5G hub - Went from 349Mb on day one - 149Mb on day 2 - 14Mb on  day three.
At this drop off rate I'd be better off sending letters than emails.
MymsMan
How are you measuring speed?
Eero hub speed test?
or PC/phone?  with wired or WiFi connection?
The reason for asking is that I initially experienced inconsistent speeds when I first moved to three but this turned out to be issues with my laptops wifi settings rather than the underlying 5G signal.
By checking the speed using the eero app you eliminate the home network overheads from the measurements.
If you are still having issues:
  • Check you postcode on the network status page
  • Try rebooting the external hub
  • Check your outdoor hub signal strength and try other location around your home
  • Contact support by phone or chat
Qdrew
Hi, i have the same problem. After a good start approximately 3 months ago its now very inconsistent and keeps dropping out. Some tablets will not recognize or join stating " no signal" Very frustrating. I am in Doncaster DN4 area.
Terryh
Same here
Roy52
Same for me great at first now I can't even watch TV Massive ping and slow speed. What's going on?
MymsMan
Rebooting the hub until I get a new WAN IP address has always resolved periods of high pings for me.
You can also disable scheduled rebooots in the hub settings.
Bobbert0913
Do not get a three 5G router or sim deal. Stuck with the worst most unreliable connection ever for another 18 months. Moan and get deflected and nothing gets better. The 5G router drops out all the time but 5G at home on my phone is fine so why?? Crap company to deal with
Noodles
I can barely stream a TV show and scroll on my phone at the same time without something freezing. The hub has been on every available surface in the house and only ever manages to achieve poor to fair signal. Luckily, my contract is up in August and I won't be renewing.
BeCooL
my first dongle  was 3g before and I was getting 6Mbps. Second was with EE 4g and I was getting 70 - 87mbps. Just moved to three recently. I have new 5g wifi. I am getting 660kbps to 2.2mbps. Well I have 10 days to cancel my contract. So it is not worth it at all.
