on 19-09-2024 01:31 PM
Three supplied Huawei B535-232 router has started to be very glitchy. Sometimes not able to log into web interface without restarting it and other times it just stops passing data completely requiring another restart. Also issues with receiving SMS's (that could be a network issue though) It doesn't appear to have had an update in quite a while, Three support weren't helpful when I asked them about the latest update available.
Can anyone clarify these are the latest for this model ?
on 20-09-2024 02:51 PM
Hi Jonathan
Many thanks for your response, I have restarted the router and re-checked but unfortunately it still shows
on 20-09-2024 02:57 PM
Thanks for the update Mark, and I'm sorry to hear it wasn't resolved so simply, but I'm sure we can figure this out.
I've sent a PM to check some more info with you. Please get back to me there when convenient.
on 20-09-2024 11:06 AM
Hi @X2701,
I've been advised that B535-232-CUST 11.0.1.1(C21) is the current version, so I've flagged this up with some colleagues for you. I'll let you know if we need any more info or for you to try any troubleshooting steps.
on 20-09-2024 11:48 AM
Hi Mark,
My colleagues have advised this ought to be fixed now, can you give the router a quick reboot and let me know if the software has updated please? Please let us know how you get on with the other issues you mentioned if the software is corrected now.
