on 13-09-2022 10:54 PM
on 14-09-2022 09:05 PM
Hey,
That's the one!
on 16-09-2022 10:37 AM
Hi @Crystal_Maze,
Thanks for your patience on this one. I was just getting clarifications from a couple of our specialists before following up.
Unfortunately this router does not have any options to change the DNS settings. It might be worth checking the settings menus of the devices you connect to the router though, in case you can set custom DNS settings on a device by device basis.
Hope this helps,
on 14-09-2022 02:51 PM
Hi @Crystal_Maze,
Happy to help look into this. Just to check, this Qualcomm chipset is used by several different devices. Is it the Three 5G home router that you're referring to? I'm assuming you mean the 5G router listed on this page?
