on 13-02-2024 10:41 AM
I'm using the Huawei 5G CPE Pro 2 for my home broadband, but recently my IP address is changing every few minutes.
This makes it impossible to do things like logging into secure websites such as banking, as it deems me as a security threat.
I've tried to login to the router settings and change the APN (as suggested here), but I don't appear to have that option in my settings (see the image below)
I understand I don't have a fixed IP, although this would be ideal, but it used to change weekly, and now it's happening every few minutes.
on 30-12-2024 10:33 PM
I have the same issue, no option to change the APN.
How do I fix this?
on 19-06-2024 12:26 PM
I'm not using the above router, but andyvee's suggestion worked on my ZTE router using the 3internet APN. I am set to 4G only and allowing IPV4 addresses only (not IPV4 and IPV6). Prior to this, the IP address was changing every few minutes.
on 06-06-2024 08:22 AM
Did you get to the bottom of this as I’m facing the exact same issue
on 16-02-2024 10:15 AM
I'm not able to set any APN or IPv4 / IPv6 settings - I don't have the option which appears in other solutions frustratingly!
on 16-02-2024 01:23 PM
Are you on an up to date router firmware as Huawei routers should have an option to set an APN on the internet connection.
on 16-02-2024 02:14 PM
I managed to view my router information by using https://hirouter.net/api/dialup/profiles - and by the looks of it, the APN is set to 3internet, and there is no IPv6 info setup (which I assume means it is IPv4 only) - so back to square one in terms of what might be causing the issue
on 16-02-2024 02:12 PM
Yep, just double checked and it's all up to date.
There's just no option to add a new profile in anywhere
14-02-2024 05:36 PM - edited 14-02-2024 05:37 PM
I'm seeing the same on a NR5103E if IPv6 and IPv4 are enabled on the APN. Manually set the APN to IPv4 only and all is well.
