on 08-05-2025 03:47 PM
Ever since I got three broadband (been almost a month), the service checker has said: "We're working on fixing an issue in this area at the moment. We're sorry for any disruption this may be causing". Not my actual post code but near enough: CV34 6RH
When will this be resolved? Three is our only option for internet [that or copper connection from BT] and we're constantly running into issues.
We've also had to switch to IPv4, as IPv6 [with Three anyway] was interferring with developing/testing multiplayer within Unity [another option was to switch to three.co.uk. Also seems three's network experiences packet loss where its communicating saying its finished a download but in fact gets stuck at about 90-99% [Unity hub downloads]. The workaround for that seems to be using a VPN only; it doesn't work on 3internet nor three.co.uk. We wfh as software developers in Unity, and it's a serious issue that needs to be addressed by Three and give a definite answer to what the problem is, or at least acknowledge there is in fact an issue that's being worked on- with a timeline.
Also, the ping. This is advertised as a gaming broadband when it just simply isn't good enough. On the 5g broadband i get anwhere from 30ms to 60ms, with big spikes every minute or so to 200ms which makes it unplayable. If I however hotspot from my phone I get a stable 40-50ms. So why am i paying for this 5g broadband/modem when everything just seems to run -better- from a mobile hotspot? Very frustrating. My connection also seems to be about -70, so pretty good.
on 09-05-2025 11:08 AM
Hello, Rayner.
Broadband issues can be super frustrating. It seems like you're being impacted by multiple things at the same time, which isn't ideal. You might find advise here from other users, and perhaps in other threads. We'd be unable to complete additional checks on the postcode you mentioned though, as we don't have access to the facilities the network team would use.
I'd recommend reaching out to the Home Broadband team for additional checks to be completed, and options explored.
on 25-06-2025 07:58 PM
The ping and latency issues have been fixed for us for about a month now 😀 the issues with Unity still persist though, but at least we can work around that.
on 26-06-2025 05:23 PM
Thanks @RRayner, sorry to hear the Unity issue was unrelated though.
As you're clearly quite familiar with that software, are there any error messages or system logs which possibly give more insight into these failed downloads?
on 04-07-2025 12:59 PM
It's the same info/issue provided in this thread:
https://community.three.co.uk/t5/Broadband/File-downloads-are-truncated-on-Three-Broadband/m-p/52733...
on 04-07-2025 02:00 PM
Thanks @RRayner, I'll check out that topic and check how we can escalate the feedback there.
