Port forwarding NR5103EV2
G2Sniper
I have a strict NAT type on COD Warzone and I have tried to set up port forwarding to open the NAT and sort this issue, unfortunately it didn't work and I'm not sure whether I did the portforwarding correctly. Once the rules were added each of them had a amber lightbulb next to them?
Any help with this would be greatly appreciated as I can barely connect to warzone matches or voice parties inside COD.
I have also enabled UpnP and this didn't work either, I'm on PC.
1 REPLY 1
jr0
Key player
hello
I've seen smilar posts in this forum, and generally the solution seems to be to change 3internet APN to ipv4 (from IPv6)
I think the following might be the most recent post https://community.three.co.uk/t5/Broadband/UPnP-not-working/m-p/42851
