Router help
Aaronkr
Hi, I have the NR5103E hub but it's proving dreadful for taking voip calls. Is there any way that I can reduce my jitter? I have plugged directly into the router using an Ethernet cable and have the router positioned on my window cill and getting excellent connection. Is it possible to configure the router so it prioritises and gives more bandwidth to my work laptop?
1 REPLY 1
Officina-red
Very long thread on ispreview forum post 1679 might be of some help, https://www.ispreview.co.uk/talk/threads/new-three-5g-hub-nr5103e.38663/page-84 they are helpful people on the forum, would be worth joining to ask.
