on 07-12-2022 08:34 AM
Got a brand new ZTE MC801A from three yesterday Every 12hrs approx. The speed drops from 800Mbps to 50Mbps, sounds like it’s dropping to 4g, the only way to get the faster speeds is to reboot the router.
Also, why was I sent the ZTE MC801A and not the
Zyxel NR5103E?
on 07-12-2022 01:44 PM
Same thing with me when I joined 3 last week. The other issue with these older Hubs is that they are incompatible with the app which features only the NR5103E. I suppose they have a load of old stock to get rid of, but it's a p1ss-take for sure. They need to take note of the excellent service provided by their colleagues at Smarty. I seem to have got mine working better now by suspending it in a string bag at a height of appx 6ft and right up against a window, although I'm still undecided about whether to keep it. Hope your works out OK in the end.
on 07-12-2022 03:50 PM
Thanks, I set mine to 5G only and it seems to be ok now, the speed hasn’t dropped all day.
Still pissed about the old version but at least it works ok
on 24-12-2022 08:05 AM
@Nxt I've been with three 5g home broadband for months now with no issues but last week or so I've been getting same issue, speed dropping from 800-900 down to 90, rebooting only way to solve it. Full signal strength and says its connected to 5g. Was just wondering how did you set it to 5g only? I have the zte mc801a too
on 24-12-2022 08:52 AM
I've managed to work out how to select 5g nsa but it's dropping back to 90 within minutes. If I select 5g sa I can't get any service. Think I'll keep It on auto because that seems to last the longest🤷♂️
on 01-01-2023 10:45 AM
Any one had any luck with this? Speed has started dropping again with in an hour of rebooting router, that's only way to get it back to full speed🤔
on 08-12-2022 04:05 PM
Hey @Nxt We're not currently selling or upgrading to the Zyxel router, while we work to perfect it's performance with our network.
Our MC801A is still a great product though - I'm glad you were able to adjust the settings and that your speeds are staying steady.
@Jax You should be able to use the ZTELink app to manage the MC801A router settings. Let us know if you have any issues with that, or with your connection. We'll do all we can to help.
