on 29-04-2024 12:44 PM
Hi, I purchased the 5G Broadband with Three a few months ago, I was dubious it would be a good solution however I was very surprised to find the 5G network in my area is brilliant and I went from 30MB To an average of 500MB. I gave it a few months and now I want to extend it out to my network system.
I plugged my Eero main router into the 5G router and from the Eero app ran a speed test, I'm getting 750+ which looks great, upload speeds 100+ too. however, as soon as I run a speed test on any device connected via wifi to the eero network I'm getting much lower speeds (like 50-60). and from the same range i try connecting to the 5G router and I get good speeds of 500 again so I'm wondering is there a particular set up I need to run in order for Eero and Three router to get along correctly?
The Eero hubs are not more than 10-12 meters away from each other and I believe they are optimally spaced.
on 30-04-2024 12:13 PM
Hi @AdEero2345G,
That does seem like a considerable drop in speed. You might be seeing slower speeds like this if devices are connecting via 2.4GHz rather than 5GHz Wi-Fi?
Are you running the ZTE in a bridge or IP passthrough mode, or did you just plug the Eero router in and keep everything on the default settings?
on 17-07-2024 08:29 AM
Hi JonathanB, I had to turn off the WIFI signal so it didn't interrupt the Eero router, I also had to change the APN to use the IPv4 PDP Type has previously I couldn't access my work VPN otherwise it's been left as is.
