on 07-04-2023 12:21 PM
The Firmware Upgrade page displays two different interfaces. The first instance displays which current version and to upload from a file. The second instance shows an additional Upgrade Options tab to check for the latest firmware and to enable/disable Auto Online Upgrade.
Most of the time, I see the first instance but occasionally I see the second. This problem already existed in b12.
I think it should display the second as the instructions says, "You can download the latest firmware file from the manufacturer website of this device."
My router upgraded from b12 to b14 automatically when I had disabled auto online upgrade. It seems the Online upgrade tab features have been disabled but the tab erroneously displayed. Please can this be fixed for the next firmware.
4 weeks ago
I also have not been able to auto or manual update, and get a certificate error when connecting to the config page, currently on V1.00(ACBJ.0)b15 not sure if there are any updates available to manually install
3 weeks ago
Hello there.
The Hub updates on it's own when updates are pushed to the device with automatic updates enabled. The network doesn't release update files for manual installation.
on 10-22-2023 11:09 PM
I'm 6 months late to the party here but yeah, where did that auto update option go?
