on 25-03-2023 06:08 PM
Hi below are my settings for APN settings. Can someone advise if they are correct or not. I have a sim only deal in an unlocked Motorola moto e20. Where I've put greyed out, it means setting cannot be altered.
Name 3 uk
APN three.co.uk
Proxy not set
Port not set
Username not set
Password not set
Server not set
MMSC http://most.um.three.co.uk:10021/muscles
MMS proxy 8799
MCC 234
MNC 20
Authentication type not set
APN type supl,default,mms
APN protocol IPv4
APN roaming protocol IPv4
APN enable/disable (greyed out)
Bearer unspecified
MVNO type none
MVNO value (greyed out)
on 10-04-2023 07:40 PM
Hi JonathanB
APN type Internet + mms doesn't work for me, it leaves me with no Internet connection. After reverting back to supl,default,mms I have an Internet connection.
Regards
Paulus
on 25-04-2023 02:21 PM
Hi @Paulus,
Sorry for the delay in checking back on this one. Yeah the instructions about "Internet + MMS" were from quite an old version of Android I suspect, it's pretty rare to have to key in APN profiles manually these days.
Thanks for flagging this up, hopefully this'll help other users in the future. Is everything working okay for you in terms of mobile data since you last posted?
on 25-03-2023 06:22 PM
Sorry but MMSC http://most.um.three.co.uk:10021/muscles should be mmsc not muscles and MMS proxy is 217.171.129.2 also MMS port is 8799
on 29-03-2023 12:23 PM
Hey @Paulus,
Usually most handsets will pick up the correct settings, and most of the above are correct, although I'm not sure if an auto-correct may have kicked in when you were entering the MMSC?
Here's the fields you may need to enter manually, and the rest look right to me, but don't normally need to be changed from default:
APN: three.co.uk
User name: [leave this field blank]
Password: [leave this field blank]
MMSC: http://mms.um.three.co.uk:10021/mmsc
MMS proxy: 217.171.129.2
MMS port: 8799
APN type: internet + mms
Let us know if those are working for you.
on 09-04-2023 09:47 PM
Hi JonathanB
Thank for your reply and suggestions also apologies for late reply, plenty of reasons for being late but no excuses lol. Only now picking up and I've changed manually APN type from supl,default,mms to Internet + mms. I'll see how this change goes and post back here the results.
Thanks again
Paulus
