on 10-07-2022 04:47 PM
If you have high iPhone watch what do you need to do so you can use your watch and take calls anywhere without having your phone with you
on 10-07-2022 08:39 PM
Hi Pemberley39,
Can you confirm what kind of Apple iWatch you have? There is normally a model with cellular support (allows you to make and take calls without your phone near-by) and the normal Bluetooth model (which only allows the calls feature if you iPhone is near-by).
Have an amazing evening.
