on 29-01-2025 02:48 PM
When I call a telephone number indoors my iPhone takes ages to connect outdoors it connects straight away
a week ago
This is because your phone is struggling to connect to the network outside; most phones default to the higher frequencies so it struggles with the uplink. Get a booster for inside your house
https://www.frequencytelecom.com/search.php?search_query=C41
a week ago - last edited a week ago
Better to “default” to WiFi calling. Simples!
And a blooming sight cheaper as well!
on 30-01-2025 02:01 PM
Hey @Davycrocket
Great advice given by @Paddiewack and I would agree the infrastructure can play a part.
How long have you had this issue?
If you enter your full postcode here, this will give you some insight into the coverage in the area.
You can also chat with the team here for further support on the matter.
Jade
on 29-01-2025 05:53 PM
Sometimes indoor coverage can be patchy despite it being ok outdoors as the mobile signal can’t always penetrate walls so well, If you have broadband then my suggestion would be to turn on WiFi calling on your phone. It will then solve all your problems.
