on 09-10-2023 09:01 PM
Hi all, I was told when renewed my pay monthly contract earlier this year that I would not have any trouble using my phone abroad in Jammu, India, as go roam was active. However, I have received no network related messages and even on checking for network manually, I have no signal in Jammu, none of the local operators are picking up my attempts to join! I can't see any option for live chat, am locked OUT OF My3 (OTP can't come through!). Any advice please?!
on 15-10-2023 08:13 PM
Thank you!, tried all except switching off data roam to get OTP!!! Will try.
on 12-10-2023 08:11 PM
Unfortunately, India isn't covered by either Go Roam or Data Passport........
on 13-10-2023 01:04 PM
That's right, here's the link to Roaming info for India.
@jw1 the best advice we can give is to get in touch to check roaming is definitely active, and that your usage isn't being restricted by credit limits on the account. The rates are quite high there though, so you may be best to check into local provider's options as was suggested.
Receiving texts is free, so assuming you switch data roaming off in your phone settings you may be able to pick up OTP at least. If your phone isn't providing service automatically, you can try checking for network or carrier selection in your settings, and with this on manual instead of automatic you'll get a list of available signals. If you try selecting these and testing them one by one that may get you service.
Hope this helps,
on 10-10-2023 12:03 PM
so true!
on 09-10-2023 09:29 PM
You may need a local sim as it appears that the Indian government may be blocking outside sims for security reasons. I suggest a trip to a local phone shop. By the way the scenery looks stunning.
on 10-10-2023 09:41 AM
Thanks! The scenery can be spectacular indeed!
The OTP (via text message) from the UK still won't get through though, even with a local sim.
on 10-10-2023 10:31 AM
Just as likely to be the Indian government as a problem with 3.
