on 24-07-2025 10:15 PM
hi i just want to know if my auto top up is a data pack, how can i check this?
on 28-07-2025 11:12 AM
Hi @bryonybeanland2,
I'm not totally sure I'm following, if you set up an auto renew data pack, then it should renew each month for the same pack allowances. Did you see some information which suggested this wasn't the case, or has your auto renew not worked for some reason?
