on 19-02-2024 12:26 PM
Has anybody figured out how to get the THREE_WIFI service on the tube to work reliably? The old Virgin Media system used to work just fine for me - a little clunky but mostly worked. But the THREE_WIFI system seems to be a disaster. My phone rarely, if ever, automatically connects. And when it does it can never hold a connection. The connection almost always drops within a few seconds and I have to manually try to get it to reconnect. More often than not the train is leaving the station and I still haven't been able to establish a usable connection.
I saw a few threads about this from last year but nothing recently. Does the system now work for most people, and it's only me who has the issue? Is there some trick to getting it to work?
I'm using a fully up-to-date iPhone 13 Pro if that's relevant.
on 20-02-2024 09:47 AM
Doesn't work for me either - tend to use my work phone with o2 instead which gets excellent coverage across the Underground.
on 20-02-2024 09:59 AM
When you say it doesn't work, do you mean you can't connect to THREE_WIFI *at all*? Or that you have the same symptoms as me, where it *is* possible to connect (manually) but the connection just won't hold for more than a few seconds?
on 14-12-2024 08:44 AM
i recently had to reset my WiFi settings on my phone and since then haven't been able to connect to the station internet. I use an android and have followed the steps multiple times and it doesn't work
