on 31-10-2023 01:36 PM
I got 3 sim base on recommendation but the network has been scrappy since day 2 and it's very frustrating.
The network in my area at Mansfield is very poor.
on 31-10-2023 07:06 PM
2 points:
1. Did you actually use a coverage checker? I suggest you try the OFCOM offering as you can go to address level.
Broadband and mobile coverage checker - Ofcom
2. Have you checked to see if work is being done?
Network Status Checker - check your signal and get support | Three
